A/C condenser on outside of the bus? - Page 3
Started by Tikvah, July 28, 2012, 03:37:15 PM
Tikvah
QuoteI am concerned about "dirty power" causing problems
I would like someone to address this issue.  Are the mini-splits overly sensitive so that they risk damage from our generators?
Dave
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
I doubt the splits would cause generator problems maybe the other way around dirty power will do sensitive electronics damage that why most electric fridges are ran through the inverter on RV's so I was told
I do know for a fact generators if not set right will do the control board damage on the ducted RV AC unit like a Carrier or others and the 110 control board on the RV fridges
With the splits I have no idea but I have seen 3 replaced on the split units switching from shore to generator that is all I know
robertglines1
Maybe Jerry and others that have been running Minni for years will see and chime in. I know Dwayne have been in use for 5 yrs.. I think Jerry steps his voltage up to the 208 units. I'm learning as I go and will adjust. I built basement air out of 2ea window ac and it worked for 7yrs till I had a ground failure that surged 220 to a unit and fried one compressor. left one basement running. the ground failure was in a 50 amp factory plug end and was intermittent.  Bob
Quote from: robertglines1 on July 30, 2012, 09:52:11 AM(snip)  I think Jerry steps his voltage up to the 208 units.  (snip)
     Does Jerry run 3-phase?  If so, I hope that he'll tell us why.  Thanks for the info, I really appreciate the guidance on this one.  Best wishes,   BH  NC USA
robertglines1
Actually I was confused to : my house unit was advertised 208-230  when I got it it just showed hooking up two hot wires to it  (line 1  and line2) and green to case-- what I consider safety ground.  It runs  9 am draw 24000 btu.  The same way we hook up some three phase motors and make them run on non three phase current.  I DO NOT UNDERSTAND.  not yelling  I just don't. Just might be 220 without ground.  past me. I understand Jerry steps up voltage. Maybe to 220 with ground.   I don't understand this inverter DC 48volt theory just know it's working.  Prob would fry my brain LOL   Bob
Quote from: robertglines1 on July 30, 2012, 11:11:34 AM(snip) .  Prob would fry my brain LOL   Bob
     If it's got those electrictron things, it *will* fry mine!  But usually 208V is 3-phase but that's about all this inexperience mind knows.  That big a capacity unit would be wonderful if it would run on 120V.  I'm looking forward to more info so I can understand.
3 phase compressors are only used in commercial refrigeration and you cannot start one on a single phase
I followed advice here on how to start a 3 phase electric motor on single phase and can tell you for sure it doesn't work on a 3 phase Copeland compressor and I cannot see a single phase compressor working on 3 phase either
208 volt can also be single phase.  A building that has 208 three phase can supply 208 volt as single phase.
Tikvah
This topic is sliding off the wrong side of the hill.  I don't mind, but I'm still looking for ideas and advice.
Any problems placing the condensers outside the bus?
Is there a problem with generators not producing clean power that will affect the Mini-Splits?
Those who use the Mini-Splits already, If installed in the bay, how do you get enough air flow over the condensers?
I'm only using 4K 115V
Dave
1989 MCI-102 A3
On a 3 phase building using a single phase 208v what do use as a return path for a AC unit ?
robertglines1
I know it does Dave but is sort of relevant, if your gen set has two legs. two separate line feeds.  Clifford no return path.  I don't know how it works.  Dave many have been run successfully on gen sets. The question at hand I think is can the be run on inverter style gen sets? which yours is not.  Sorry for thread drift.  We are all looking for answers also. Looking to be noted the ones Clifford mentioned were run (if I remember rite) almost 100 thousand miles. Probably more miles than I will ever put on mine and I assure you I will watch mine more than a driver for hire.  Good solid mount and solid line mount will be the secret to success. In bay a vented exit the size of fan blade on condenser and a larger intake with forced air from supplemental fan to overcome road vacuum when driving. When parked no need for extra fan. I know that from experience. suck in bottom exit out side..   The fan moves allot of air and is variable speed as needed.  I did seal fan exhaust against door with soft rubber so it would not recirculate it's own exhaust air.  Bob
