Plastic tank fittings
Started by bobsw, January 22, 2010, 09:41:52 AM
bobsw
I want to install a overflow from my gray to the black tank. The tanks are plastic. All of the fittings I have found you have to have access to the back side of the fittings. How can I get fittings that the female end of a hose would attach to into the tanks so they don't leek or fall out. Any ideas?
73 MCI-7
fe2_o3
     Bob;   Mine are connected through the plumbing. I can open the dump valves from tank to tank without opening the last valve to the dump hose. Gravity will even the tank levels. Sofar..Sogood No problems...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
philiptompkjns
Quote from: fe2_o3 on January 22, 2010, 11:36:59 AM
would getting shet in the gray tank be a problem?
1990 102a3... Just got started, don't  know  what I'm doing.
fe2_o3
   Nope. Open the valve and the fuller grey water pushes its way into the black tank. Close the valve before or when the two levels are equal. Yes, you have to pay attention....Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
bobsw
We only dump gray water with the black so it will not make any difference.
73 MCI-7
fe2_o3
  So, Bob; Does that mean you can dump from one tank to the other with out dumping to the hose?...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
bobsw
When the gray water tank gets full I would like the the gray water to flow into the black tank. The gray water always fills up faster than the black. I just would like to extend the time between dumping.
73 MCI-7
