PD4107 Slack Adjuster Part Numbers
Started by gus, June 18, 2012, 04:14:07 PM
Does anyone have current part numbers for PD4107 Slack Adjusters? The arm centers are 5-1/4" and 7" c-c.
I have the parts book but those numbers get me nowhere.
I assume they are generic Bendix parts, nothing special. They are Bendix Series PL-20 but there are many, many part numbers in that series.
My local parts store probably has these if I can get the correct numbers. I assume left and right are different numbers, they are in the GMC parts book?
roadrunnertex
For a 4108 which just might be the same as a 4107 ???
left 2473361 MCI part number 4C-6-1
right 2473362 MCI part number 4C-6-2
FYI Luke at US Coach has both in stock ;D
jlv
John,
Thanks, those GMC PNs are the same as for 4107 rear adjusters but I haven't been able to cross them with Bendix numbers. After I posted I found two new rear ones in a box in the bus but don't know for sure if they are correct.
Do you have the MCI numbers for the two fronts, 2473353 and 54? Based on the rears they probably are 4C-5-3 and -4? I might have better luck with MCI numbers since they built buses long after GMC quit.
roadrunnertex
Gus,I do not have the MCI part numbers for the front slack adjusters.
Sorry.
jlv
John,
I have them on order and will email the the numbers to you if you want.
roadrunnertex
