Which compartment is preferable for generator install? - Page 2
Started by Mex-Busnut, August 03, 2011, 08:05:50 PM
thomasinnv
Clifford, you are correct. I found the numbers somewhere when I was building my bus but can't locate them right now. The rear bay was rated for well over 2000#, the front bay not far behind, and the center bay came in last at somewhere around 1500# if memory serves me correctly. There is no doubt in my mind that when these were revenue buses they exceeded those ratings often. My memory is not what it used to be so I may be off by a bit, but I know they are in that order from least to greatest.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
Bill B /bus
On this bus, MCI 102A3, the generator is mounted in the old condenser bay. The house batteries are in the original position 2 and 4 where the heating and AC exchangers and blowers were mounted.  Six 8D AGM's are about equivalent in weight to the removed equipment. The generator set weighs about what the condenser and its fan/motor weighed.
Rear bay, of three, is full with plumbing, aux fuel tank and Webasto.  Tanks are 125 gallons each, water and waste. Aux fuel tank is 45 gallons for Webasto and genset.
On a two bay bus you will only have one for your stuff. As the plumbing pretty much takes about 2/3rds of one bay.
Bill
Bill & Lynn
MCI102A3, Series 50 w/HT740
