Prevost Temperature control
Started by eventer1, June 02, 2011, 11:06:52 PM
eventer1
I am missing the potentiometer to control the temperature. I think its part # 870963. $470 seems a little excessive from prevost. Doea anyone know where I may source a used one or an alternative?
Joe Camper
How have you concluded this is what you need?
What year bus?
Is it for a dash loop or for the coach side on a bus with OTR A/C?
What is going on is it max cold or it does not get cold enough?
eventer1
Joe,
It's missing. PO removed it, so all I have is a hole in the dash where it should be....
Its the driver control for the front hvac. Possibly happened when someone helped themselves to the radio.
Goodson Bus sales is parting out a couple 1998 model H -45 if that helps he will probably have what you need,engines and transmissions are out already they won't be there long
chuckd
On my 79 conversion, the potentiometer is a Danfoss unit.  Not sure if that helps or not.
Chuckd
robertglines1
K&R Truck sales Used parts is parting out a 91 prevost ask for Mike That part wasstill there a week ago  Holland Mich.  Bob
jok
The potentiometer to control the temperature in my 1990 XL went bad and I was not willing to spend the money to replace it.
Instead I used a switch to activate the existing electric valve in the coolant line, which is in my spare tire compartment. I can only have the heat full-on or full-off. I control the temperature with the fan speed. I put the switch next to my dash air conditioner switch. I labeled the heat switch "Heat Bypass".
When I'm cold I open the valve, when I need air conditioning I close the valve and switch on the dash air. And when I am comfortable I leave the air off and the heat valve closet.
Works for me,
1990 Prevost
1977 MC8-Sold
Southwest Michigan
Joe Camper
Before you try to put another part from another year call Prevo parts elgin and give them your Vin and the year the replacement part is coming out of . They will tell you if the part is the same part#.
Lots of these components are very YEARLY specific they change things constantly.
There are all kinds of over complicated expensive control circuts that can be redone simpler and for way less doe. That is one of those decisions that when you make that leap there is no going back. I'm not going there. That depends to a great degree to what you have to start with.
I think many new owners me included tear stuff out early on that later you learn that was dumb. If you have an old charter and a bunch of the original stuff is broken down if your gonna remove components hang on to everything till you are darn sure you will not regret discarding it.
eventer1
Thanks everyone. I will call down to the K&R next week. In te meantime I am going to try the switch solution John has suggested. At leat that way I can confirm the valve is working correctly, in case I need to order that as well.
Thanks for all the help.
eventer1
Tracked down a wrecker NW of Edmonton has 8 Prevost XL he is parting out. Sturgeon Towing & Truck Repair
780-914-7560
I am going to run up next Friday. I'll post if he has other models as well.
