Eagle in scrap yard
Started by robertglines1, May 12, 2011, 05:07:23 PM
robertglines1
Here in Holland Mich picking up parts for my prevo and a couple other bus nuts prevos and there sits a seated Eagle with good looking skin I will ask more questions in the morning but it was in the processinbg area. Must be newer coach has the bigger windshields. It is a truck wrecking yard. Big operation.If I were to look for ID# where>?   Bob
boxcarOkie
Quote from: robertglines1 on May 12, 2011, 05:07:23 PM
Usually has a stamped plate, welded to the frame in the engine compartment, passenger side.  Often hard to see, you have to work at it but that is where I found mine.  It is a small metal tag with the id numbers stamped on it.
BCO
Should have a tag over the drivers area if a 102 wide model 15 the plate will be in the AC compressor compartment on the passengers side at the rear you really cannot tell by the windshields look at Eric's model 10.
robertglines1
I have no personal intrest just looked straight and shinny. Hate to see something that clean looking melted down and made into Kia's. Will post what I can find out with contact info.  Bob
demodriver
Mine has a vin tag in the clove box. When you enter the bus look to your right on the stairs. Theres a door built into the dash.  This is where all the gvw info is for mine aswell.
rusty
If it is a late model 15 the number is stamped in the plate the AC compressor is mounted to on the right side of the motor.
Wayne
robertglines1
Bus is on hold. has been there since 2009 with blown motor. They are contacting owner!.Will advise Me if there is any change.Great looking seated coach. Body next to perfect. Church group been advised rebuilt engine will be in 18grand area and used in 5 to 6 grand area over a year ago. Maybe a gental aproach might lend someone to a treasure. I'm not a Eagle guy: I do admire them! I did not push for further details.  Bob
