3 way fridge help
Started by demodriver, May 09, 2011, 07:21:50 PM
It won't get very cold on 12 volt plug in to 110 and leave on for about a week it will start working better those fridges will last for years if they are working everyday sitting idle is the worst you can do for one
Don4107
To work well they need to have the correct spacing from whatever backs up the fridge.  If you are testing it sitting in the open it won't work as well.  Needs the correct chimney effect.
Good luck
Don 4107
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
Ir will never cool down on 12V only. It won't even stay cold on 12V even if it is cold to start with.
12V is for emergencies only or maybe during cold weather. Hot weather, forget it.
Barn Owl
QuoteIr will never cool down on 12V only. It won't even stay cold on 12V even if it is cold to start with.
Amen.....
I thought it would be a great idea to run on 12v and save on propane when we did some 700+ mile days. I thought my fridge was bad! 12v is worthless! Propane will freeze it up but sometimes it still struggles in very hot weather. Cool your stuff ahead of time if possible.
I bought an indoor/outdoor thermometer at Walmart that has a remote sensor that I keep in the fridge. Now I know how hot the driver's area is and if the fridge is staying cool.
BarnOwl,do have a 2 stage regulator or 1 stage the 2 stage regulator are not bad about freezing unless the vent hole is turned up instead of down or if they are installed on the liquid side instead of the vapor side and fwiw not to start a war here but the regulators are supposed to have a cover  to help with that problem also
Cary and Don
Since we don't have it hooked up to propane,  I guess we will make sure it is on the inverter for 110.  We are considering installing a small propane tank to run it in case of emergencies or when the inverter is off.
Don and Cary
1973 Eagle 05
GMC 4107
Neoplan AN340
1973 05 Eagle
Neoplan AN340
Barn Owl
QuoteBarnOwl,do have a 2 stage regulator or 1 stage the 2 stage regulator are not bad about freezing unless the vent hole is turned up instead of down or if they are installed on the liquid side instead of the vapor side
If it is the propane regulator I would guess it is a one stage. I should clarify that I can freeze the fridge if I turn it down low and don't open the door a lot, and then especially if it is cold outside.
It is a 1979 Dometic, and though not perfect and requiring me to keep tabs on it, it works. A real PIA to light and remain lit if it has been off for a while. That's where the thermometer becomes invaluable.
Go the propane route they will run for over a month on 5 gals going 110 through a inverter the batteries won't last 8 hrs without charging
demodriver
Quote from: luvrbus on May 11, 2011, 04:17:15 PM
Can I get a two stage regulator at the hardware store? Or is it a rv surplus thing?
Hardware stores,Propane dealers,plumbing supply about anywhere but a RV dealer LOL buy the adjustable type
As Cliff says, forget about running it all the time with the inverter.  The power required is high because it is a resistance heating coil, nothing like a house frige.
LP is so efficient and cools so well, uses very little LP.
