4106 Generator question
Started by eddieboy, April 12, 2011, 10:40:55 AM
eddieboy
1962 PD4106, I am about to get her on the road.  I have a generator light on until I flip the main blower fan on.  Once the blower is running, the gen light goes out.  I'm wondering if the blower is completing the ground to make the generator see a good load.  The batteries are pretty much toast.  They won't keep a good charge even from an external charger.  In fact, I can jump the engine with my Dodge Ram 1500 and she atarts right up. Any theories?  Thanks for the help.
Ed
Ed Spohr/1962 PD4106/8V71/4Speed/Zion,Ill/Far North East Corner of Illinois
eddiepotts
Most people on here say it will not energize until it sees a load. Try just turning your running lights on with out the blower and see if it makes it turn off also.
eddieboy
I did have other things running and only the big blower motor made the light go off.  Everything else kept on working, so I don't think it is shorting anything out.  Blower runs fine as well.
If you have the original 300 amp generator it needs a pretty good size load to produce. My relay clicks on and off until I turn on the blower, which is a huge motor, or unless all the lights are on or the batteries are very low.
If your batteries are about shot they sometimes will still take a "surface charge" which makes the gen think they are charged.
TedsBUSted
Careful!
With  cooked batteries, and loads like the blower stopping and starting, the system voltage could spike up in the range of popping every  light bulb that's energized. You should install at least one good battery, even if it's just a garden tractor battery or a jumper pack.
Bus polygamist. Always room for another, especially '04 or '06 are welcome. NE from Chicago, across the pond.
Barn Owl
My gen light will come on with little to no load and a full charge. Scared the crap out of me in the middle of TX one time at the begging of my trip. Thanks to this board I remembered to turn on a load to see if it would go out......It did!
