stainless tanks
Started by phlynlo, August 28, 2006, 04:33:42 AM
Quote from: Denny on August 29, 2006, 07:40:33 AM
My situation was I have a large combined waste tank (200 gal.) and a 140 fresh tank.  The senders I used drop down from inside the coach so I put a small access plug that I can get to if I ever need to change or replace them.  One of the problems I had with my old sender for the waste tank was junk (use your imagination) on the sender.  The salesman and Wema suggested using a gauge that starts a ½ tank which works really great.  The heavy ends are at the bottom and do not hang up on the sender.  I have been using it for 3 years now without problems.  The fresh tank works great and is very accurate.
There are other senders that stick into the tank that don't have a float like the Wema has.  Snake River Electronics is one, but their senders probably only work with their tanks.
Brian Elfert
