Well I went and did it this time - Page 2
Started by wal1809, August 29, 2010, 06:24:35 AM
Paladin
Quote from: wal1809 on August 29, 2010, 11:23:17 AM
I beleive I am getting your drift on the parabola.
Well I dug out the broken dome pieces amd branches.  What the heck I powered it up.  I spins and locks on the satelites so next step is book a box up to it and find another dome.
Wow, if you spin and lock then I'd say you are in great shape...except for the dome. I dunno here, maybe totally wrong material and cost may be way out of line but vacuum formed plastic? There is a shop around here that does the kind of stuff but I'd bet the setup cost would be pretty high for a one off piece.
I wonder if a dome off of other brands could also fit? At least that would open up the spectrum a bit.
Time for the Saran wrap ;D ;D   !!
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Lin
If replacement domes are not easily available, I would guess that you could use just about anything the covers the mechanism without obstructing its function.
Paladin
Well aside from physical things like maybe a twig or leaves falling into the mechanism or on the dish or slush and snow I don't really see why it needs any cover at all. Maybe put a screen (nylon, not metal) over it and see how that goes?
-Dave
8V71  HT740
eddiepotts
It has exposed electronics. Has to be covered.
Paladin
Quote from: eddiepotts on August 29, 2010, 01:34:07 PM
Having never actually been inside one I wasn't aware of that. Thanks for the clarification, I guess a cover is in order.
8V71  HT740
wal1809
There are some really delicate looking electronics, tiny gears, belts ect.  I pulled it into the barn and I am still worried about dust getting in.  The dime looks easy to replace.  As far as I can tell it is 4 bolts and a sticky rubber gasket.  I looked on the tracstar website but it mentions nothing about replacement parts.  If it is to much of a pain in the arse I am going to call my insurance agent.  I might just take it into the shop and have them go through Otto check it out.  If is broken then now is the time to find out.  I might wind up having to replace the system.
www.snakebreaker.com
Paladin
If it's toast send it to me if you are done with it, I'd love to tinker with it and see if I could find a reasonable dome solution. Don't want to mess with mine.
-Dave
8V71  HT740
wal1809
If it is in fact toasted you are welcome to it.
cody
Call trina at RV Surplus and tell her you need an empty dome.
Hi yo silver
What about a big plastic tub over it for temporary protection, until you find a dome?
Dennis
Len Silva
Radomes, which is what that piece is, are designed for minimum signal loss.  A substitute may work OK but probably not as well as the original.  Protection from the elements, of course, is a different thing; whatever works.
wal1809
Quote from: cody on August 29, 2010, 02:18:27 PM
Will do!!
wal1809
I called Tracstar today.  $85 plus shipping.  Not to bad!!!
