Fresh hot and cold water circuits in a bus
Started by Paladin, July 29, 2010, 12:19:49 AM
Chaz
Thanx Tom. Will do.
Len,
  You mean like a spray bottle?? ::)
  Chaz
kyle4501
Quote from: Len Silva on July 30, 2010, 01:11:01 PM
If you really want to conserve water, use a manual pump in the shower. :D
My shower is so small . . . . .
There ain't enough room to pump anything in there.   :o  :-[
Ed Hackenbruch
Like Jim, i just fill my tank and run off of the pump even though i am also set up to run off of city water. I too don't want to come home and find thousands of gallons of water flowing out of my bays. :) I  have a switch in the bathroom that i can shut the pump off with and another in the bay next to the pump that i can also shut it off with. Makes it handy when i want to change the filter.... shut it off, crack the line to release the pressure and change the filter all within just a few minutes. ;D
kyle4501
I'm not smart enough to always remember to turn the pump off when I leave.
I also had a problem with a leaking valve that overfilled the grey tank. Only thing worse than waking up to grey water backing up into the shower is seeing the clean clothes (that I had stored in the shower) floating.  :o YUCK
steve wardwell
You wouldn't believe how many boats flood and sink at the dock because of a broken fresh water line in the boat fed from a unlimited supply from shore. The numbers are astounding.
Sometimes the more I think about something the less I think about something.    As soon as I save a little money my bus finds out.                                      Why grab a plane when you can take the bus ?                         If I'm wrong 10% of the time how can the "Queen" be right 100%
Chaz
Tom C.,
  I put the 2 pumps in as you suggeted. Only difference is I have all 1/2" lines. But it worked greaaaaat!! ;D The shower stayed at a nice constant, both in heat and pressure. This will hold me over till I get the hot water heater situation figured out and re-plumb the whole thing.
Just for a little more trivial info........
I bought one of the "Oxygenating shower heads" that are supposed to be so good and save lots of water, but I'm afraid they must work better with city pressure. It worked just fine but, I did not think it was "all that and a bag of chips". (definitely not worth the 40.00) I also have one of those little chome jobies, that look like a little megaphone, and it seems to work pretty good too. It shoots out water more like a mist. I have not compared the amount of water used by both of them yet, but my guess is the little chrome one uses less, possibly a lot less. The "oxygenating head" is supposed to save you water but that might be compared to a hose.  ;D ;D ;D ;D ;D lol  Just kidding, but I'm pretty sure the little chrome one saves more. The only drawback was rinsing your hair. For some of you, that may not be a big deal (no disrespect, just sayin ::)) but your wives might not like it. It took me a little longer as I have hair (from my head!) to about 3" above my belt. Stuck in the 70's, I guess.  ::) ;D ;D
Just thought I'd give ya an up date. Thanx again,
  Chaz
rv_safetyman
Interesting drift:  shower heads.
We chose a hand held shower head (with hose).  The photo of the Camco unit is similar to what we have.  You can put the water right where you want it.  I am convinced that it saves a lot of water.
Jim Shepherd
Evergreen, CO
Chaz
Both of mine are hand held as well. The chrome one I made hand held with a 5" piece of PEX and fittings. I have never used it that way but it can reach the toilet for a squirt down if needed.  ;D
Chaz
I have a Camping World (say cheapy) hand held with a turn off valve built into it.  While a water saver shower head is nice, my theory is to cut off the water while washing, but then have full flow when running to shorten the rinse time.  I haven't ever measured the flow, but I'm guessing in the 1 gallon per minute range.  Good Luck, TomC
