Radiator Mist Cooling System - Page 4
Started by DrivingMissLazy, May 25, 2006, 07:04:33 AM
Burgermeister
Aaaaaaauuuggghhh!
After you attended the "All you never wanted to know about Cooling Systems and were afraid to Ask" seminar?
What didn't I communicate?
Onward and Upward
Marc Bourget
Happycampersrus
Marc,
Did you ever find the water pump you are looking for???
Dale
Burgermeister
No, I haven't.   I need to do further research.  I understand that there's a different rotation/configuration of one pump used to reverse the "standard" direction of coolant flow - from "block to heads" to from "heads to block".  The brief explanation was flow reversal, which I understood could be obtained from a LH engine, more particularly a LH marine engine.
Now have to dig deeper!
Thanks for asking
Happycampersrus
Marc,
Thought I was on to something, but it turned out a dead. :-\  It has to a marine application, I just haven't found it yet.
I'll keep looking as I am very interested in this idea. I believe "heads to block" could be interesting.
Dale
Burgermeister
It's more than "interesting"  it is the best cooling config developed for the DD 2 strokes.  Used in Military applications.  I'll be working up the mods for my 8V92.
The mods will go a long way towards remedying MCI's failure to design their cooling system to DD specs (if not eliminate it)
busboy
When I was having radiator cooling problems I set out to build a mister system which I did.  I found some brass misters at Home Depot that are used for porch mist systems.  I used 3/8 copper tubing to plumb them together...did this because I had to route the water from the rear half bath thru the engine compartment(Hot).  I have 5 misters.  Used a manual ball valve which one of the kids can turn on from the rear restroom.  Have not used it since I got a new radiator.  When I did use it, I did notice that some water that we took on left lots of deposits, most of which I could spray off before I left to get back on the road the next day.  On a typical day of driving I would use about 20-25 gallons of water.
Happy Trails,
Brent
