tile and wood mosiac for floor
Started by robertglines1, June 21, 2010, 02:05:29 PM
robertglines1
outside box---pattern combining ceramic tile and wood flooring...granite plus cherry-----ideas...grid pattern? or sweeping curves? led embedded...idea's -----bruce flooring is same thickness as ceramic tiles.
James77MCI8
77 MCI 8
8V-71 4 spd
gumpy
robertglines1
good base is planned----all in put apreciated----this is to be the focal point of coach to take attention away from my poor workmanship on other parts....I have cherry and black granite in shop-left over from another project...also have a black marble with gold swirls.
Cary and Don
I think I would lay out the patterns to look like area rugs.  Starting with the swirling patterns you have and add the rest around that the be a boarder.  One pattern in the living area and another in the kitchen would be nice.  They don't even have to be the same pattern as long as the boarder patterns matched.  I think the professionals that do this use a caulk style grout between the two materials due to the difference in the expansion in the wood in humid areas.
Don and Cary
GMC4107
Neoplan AN340
1973 05 Eagle
Neoplan AN340
robertglines1
new idea--I like it----have brass slutter strips to border wood to tile border...I did this between granite squares on 89..gets positive coments....I have tools to cut tile and wood in any pattern..maybe make counter top to cordinate? I put last down with Ge silicon caulk:takes flooring chisle to remove and doesn't come up in one piece...have front slide could center pattern on it...
Joe Camper
Run the hardwood on a 45 and insert diamonds of stone either randomly or in a pattern.
I am putting Marble up the stairs and in the cockpit on ours and I'm right in the middle of the project now.
I have some photos I need to learn how to navigate this site though. I have done 4 different installs for friends. Use 1/4 in backer board on the stair treads it is plenty stiff without using the 1/2 in there and works better in that app.
We want tigerwood in ours and I am thinking of an an elongated compass medallion with maple and ebony wood for the center of the floor
robertglines1
bottomacher
Why not simply lay out a few ideas on the floor until you do something you like and install it. YOUR opinion is the most important.
robertglines1
will do layout....good idea.....wrong about my opion it's Judy's that counts ::)
eddiepotts
You can build your wood flooring on a piece of 1/4"luan board in your driveway. then you can cut your designs in it with a jigsaw. then lay it in the bus as a floating floor. Then cut your tiles to fit your shapes if you are going in sections of wood then tile. It makes it easier to cut clean curvy lines in the wood. it will look clean like a puzzle if tile was removed.
robertglines1
I really like the feed back I'm getting ----idea you don't necessarly think of your self...the luan idea is simple I didn't think of it..
Bottom
Bottom2
