WVO Controller on Ebay
Started by Jerry32, June 06, 2010, 06:22:11 PM
wal1809
That is the beauty of WVO.  We can use whatever we want to create a fun system.  I still can't get over when I meet people who still have no idea you can run an engine one WVO.
The only thing about using a hot water heater to heat the fuel is there is no way to move the oil across the element as it sits in the tank.  It will cause problems as the oil will sit stagnet on the element.  Using the tank is a good idea you just need to figure out how to move the oil inside the tank and get it off of the element.
www.snakebreaker.com
Jerry32
There is some problem with using steel for a tank with interaction with WVO so aluminum  or plastic is ok. have to use aluminum fuel lines too. Jerry
1988 MCI 102A3 8V92TA 740
