Aluminum holding tank
Started by scotty_vince, May 24, 2010, 10:27:31 AM
Ace
Kyle if my toilet was leaking my pump would run so that would warn me something wasn't right. For the most part all is good!
Ace Rossi
Lakeland, Fl. 33810
Prevost H3-40
kyle4501
Ace, you're right about the pump letting you know when it runs. My problem hid behind the silence of using park water pressure, the pump wasn't on, so I didn't hear the water running. . . .
That happens when you have kids Kyle we are good for 2 weeks with just the wife and I, add grand kids to the mix about 3 days lol one is always going leave water running some place but I wouldn't take anything for the stinkers
kyle4501
Since it was a specialized valve inside the toilet leaking, I simply turned off the water to the toilet & planed on buying the part when we got home. For the rest of the trip, we flushed using a jug of water. One trip lead to several more before I remembered to think about replacing the valve when the trailer was parked at home between trips. However, we & the kids have adapted well & the 4 of us can go over a week on a 30 gallon black tank. Since this is working so well (cheap), replacing the valve is a very low priority.  ;D
Alum can work for the tank, so can stainless, carbon steel, fiberglass, plastic, etc. . . . It all depends on your needs & abilities as to what will work best for your particular circumstances.
