6V92 Injector Size versus HP rating
Started by NeoplanAN440, April 13, 2010, 11:44:25 AM
NeoplanAN440
we just opened my spare 6V92 engine that from the records was rebuild for LACTMA in 2000.
i found 7G75 Injectors and the throttle delay on the right bank.turbo is AR .96
if i read the book right then we are in the less 270hp range!
do i have to open it to check for smog cams???
what would be the largest size injectors for the first try??
the engine should go into a MCI9 and im worried that it will be underpowered that way.
what injectors is everybody running (power to smoke ratio)
Eric
you'll find that's what nearly all the Neoplan transits are set for..:( I would really like to do a power add via injectors and turbo so if you do figure this out share the wealth :)! some of the boats have these babys cranked up to 450hp! I understand longevity goes down when the horsepower goes up..but i only put about 5k a year on it ! i could "DEAL" with that pushing me down the road!
Have Fun!
Eric
You might have to change the turbo-the ratio sounds too small for larger power.  The standard truck 6V-92TA had 9G90 injectors that gave 350hp.  You can go to 100 injectors, but then you have to retard the timing, starting is harder, and without a new turbo, would smoke (I know this since I did it to my 8V-92TA in my truck).  Suggest you stay with the 90 injectors- and even then you might have heating problems.  Good Luck, TomC
