Can I take my RTS to Europe for a while?
Started by Kevin Warnock, May 24, 2010, 06:55:06 PM
There is always the problem of the vehicle being vandalized while in transit.  Personally- I would try to see if you could be a passenger on the voyage over on the RoRo.  Then you could keep an eye on the vehicle while in transit.
RoRo's (roll on roll off) is the preferred way of transporting a vehicle.  Then you're assured that the vehicle will be inside out of the sea air.  RoRo's look like a big metal box that floats.  Think of them like a giant car carrier-with hydraulic decks that can be raised or lowered to accommodate different sized vehicles.  As compared to an open flat rack that can be loaded on the outside on a container ship.  Much cheaper, but then you run the risk of having the bus fall overboard and the exposure to sea air.  Good Luck, TomC
