We got her running.... with video - Page 2
Started by RickB, February 02, 2010, 12:57:00 PM
RickB
Hopefully, This will work Here is the video
Rick
RickB
In the previous post the oil from the airbox started it and it finished with a full throttle runup.
This one is smoke at idle
thanks for the help
RickB
Nellie Wilson
Rick -
Sorry to learn of your disappoining results... no fun to invest all that effort and come up with less than expected.
To my untrained eye, that blue smoke sure looks like oil. But could the (suspected) out of whack valves cause that? And 60 psi oil pressure sounds a bit much (but I base that on my 8V-71).
Speaking of, since you've got a good '71 why change? You say you want reliability above all... seems you couldn't do better than that old workhorse, leaks and all.  :)
The (potential) benefits of the repower just might be more trouble (and $$) than they're worth.
Nellie Wilson
Had to change a tire... >:(  got to put it on backward... :-\  still trying to fix it on photoshop... ??? ::) ???
Rick, Glad it started. I can't tell you much from the video, but my 692 would have smoked you out of that shop LOL! The smoke is gone now and mine was blowing oil from both tubes, I got 400 miles with mine now,the blowing oil is now just a few drips after shut down, and it keeps making more power too! But I didn't have much of a choice cause the old engine was toast and had to be replaced. Your motor did sound strong,and the smoke...  Don Fairchild told me see if it'll clean up, drive the heck out of it, but don't break it. The engine starting up rite away is a good sign, means it has good compression. Did you guys run the rack yet? I know the position you are in, all the best.V
Sure looks like you ran the 8V-92TA without water hooked up to it.  It doesn't take alot of running to burn up the cylinder O rings.  At this point, it would be prudent to take the engine apart to see what is worn and bad with it and reassemble with new replacement parts, instead of installing an unknown.  After running the engine like you did without water, I sure wouldn't install it in my bus without a full tear down and reassemble. Good Luck, TomC
Nellie Wilson
Yikes
Good point, Tom C. How did I miss no coolant to a running engine?
Well, I did say "to my untrained eye." But still...good grief! Guess I'd be blowing some smoke too.
Nellie
RickB
Hey all,
The motor was completely full of water and we had all the air out of it. I should have mentioned that earlier.
Tom, I honestly can't afford to tear into this motor like that, if there wasn't a single worn out part on it the bill could be 5-6k in labor just to check. I wish I could but I just can't justify that  with two young kids and a great running 8v71 already in my bus. I remember reading how much your power upgrade cost and thinking I wish I could afford that. I'm calling around in the morning to see how much a couple hours on the dyno will run.
I have taken a breath, and have decided it may be worth it to run it after hearing Van's story. I know you all know how valuable this blog is when you're struggling.
Thanks for being there. I am grateful.
Rick
John316
Rick,
Stay with it. You have come a long ways...Don't let it weigh on you so much. How do I know it is weighing on you? Check out your time. It is pretty early ;). Get some sleep. The alarm rings early ;D.
God bless,
RickB
Thanks John
Advice heeded...
Good night all.
Rick
JohnEd
Rick,
Do what Clifford tells you is my advice.  Has to be the cheapest way to go.  The dyno will tell you if you need to do a compression test and if the injectors are shot and even if the rack needs run immediately.  Clifford will just love his steak dinner...bet'cha.  Keep him on the phone while the dyno run is in progress.
The very best of luck Buddy,
Tom Y
Rick, I would have to agree with Clifford. But this is not a sure thing, same as your 8 71 making it out west and back. I had an injection pump rebuilt, the guy told me when I picked it up there was now a knock in it. Probally an injector leaking, I started home and turned around. It sounded like she was going to come apart. He put some injector cleaner in the tank and in 5 minutes the sound was gone. Never had another problem.
  Moral of the story trust the experts, not people like me. There are a few on here and some have had real experiences with these.           I still think it will clear up.   Tom Y
Tom Yaegle
