MC 9 Tell Tale Lights and Circuit #'s
Started by BC Bus, November 23, 2009, 07:56:52 PM
BC Bus
I am working on the Tell tale lights on the left hand side of the MC9 dash.  I am putting the tell tale lights back in the dash and am wondering if someone has a list of the circuit numbers and which socket each light goes back in.  I other words "what tell tale light is it." All of the lights are unplugged and
All of the wires have numbers on them marked with the little aluminum tags.
I can find few in Da Book, by searching each schematic but not close to finding all of them
GMC Buffalo  &  MC9
Always willing to help a Busnut !
Ednj
MCI-9
Sussex county, Delaware.
My MC-5 manual has the tell-tale circuits mostly listed in the front junction box connections list.  On the off chance that they are the same as MC-9, here is what I find at a glance:
stud       code     function
11           5         24v discharge tell-tale
13           38        low air tell-tale
26           39p      emergency brake tell-tale and fast idle load
27           35        High beam tell tale
36           11        stop lamp tell-tale
39           32        11 lb oil pressure tell-tale
41           46        back up lamp tell-tale return
47           39T      Emergency brake tell tale and fast idle return
50           60        3 lb oil pressure tell tale
52           52        fog lamp tell tale
"code" is the number on the metal tag on the wire.
BC Bus
Thanks for the replies guys. Brian listed exactly what a lazy person was looking for.  His list will sure get me started and maybe the rest will be trial and error.
Great board.  I don't post much but I read it religiously.
Bill
GMC Buffalo  &  MC9
Depewtee
I just checked my MC-9 Manual (January, 1980 version) and it lists all of the same stud/code/function that Brian listed in his post.  The only difference is the Emergency Brake Tell-tale shows as code 39 (without the "T").
Brian S.
Brian Shonk
Fort Walton Beach, FL (Florida Panhandle)
1981 Prevost LeMirage Liberty Coach
1984 TMC MC-9
