Stipping paint off sides
Started by thejumpsuitman, November 12, 2009, 07:14:47 PM
thejumpsuitman
I was wondering if anyone out there has had any experience stripping paint off the lower portion of a bus.  What I mean is removing the paint to expose the original aluminum skins, but leaving the upper paint alone.  I have seen a nice looking bus, but painted all over.  The lower skins are all one color and a different color is painted above them.  I think it would look good if just the lower portion was stripped off.  I so much prefer the aluminum to be original and was wondering if this was a feasible thing to do?  If so, how?
(This post doesn't read very well to me, but it's late, so forgive me)
1992 Wanderlodge PT-40, 1960 PD-4104
Albemarle, NC
bottomacher
Depends on the bus. Is the aluminum anodized? What will be the finish after stripping off the paint (clearcoat?) Trying to maintain raw or polished aluminum skin is a real pain in the @$#, and stripper will usually ruin anodizing.
Ednj
I know someone who has a commerical Soda Blaster. ;D :D ;)
MCI-9
Sussex county, Delaware.
Len Silva
There is a pretty good chance that the lower skin was painted because it looked bad to begin with.
Bestekustoms
Im Sure You Tryed PAINT STRIPPER Right???
Stripper In The Spray Can. I Use It All The Time.If You Watch It Close You Can Wipe,Scrape Or Wash Off As Soon As It Starts To Bubble.If You Practice You Will Get Real Good.
But Becarefull Not To Scratch Your @$# With Any Of This Under Your Finger Nails. (Not Ask) :o :) :) :o
Some Paint Removers Are Not That Powerfull.Some Are. I Use BRODY Paint Remover.I Get It On My Hands Alot. It Dosent Really Burn That Bad,Maybe Im Use To It.But As Always BECAREFULL.!!!! Some Products Can HURT You.!!! Always Wear Gloves (I Dont) But Dont Be Like Me.Use Caution Anytime You Use Anything That Can Be Harmful.
Not Responsible For Lost Body Parts Or Burned Out Eye Balls.... :o
OK-OK I Think I Made My Point.?
But Thats What I Would Try.
Good Luck
JOHN 8)
"IT IS..... WHAT IT IS"
Marcus
home depot sells a paint stripper that you can stick your hand into and not burn . Don't remember the name.
travelingfools
I used STRIPIT on my bus. Not sure of the correct spelling but its been around for ever. I remember my mom using it to strip old furniture back in the 60's ! When I did it, I painted it on and it bubbled pretty quick. I scraped it of then hit it with a hose to rinse. It would regularly splash on the stainless doors and a quick hit with the garden hose cleaned it off. Just be carefull around any rubber or plastic. We ruined a few marker lenses by not being carefull. Its nasty stuff, but it worked better than any of the other 6 things we tried. Make sure you wear gloves ! If your interested, ive got a half a can left and I can get the exact name of the product for you.
I've stripped my share of  aluminium.  I don't think you'll get to what you want with stripper and scrapers, but you can get close then take it to a media blaster who can blast it with walnut shells or soda.  That will get what's left around the rivets and the seams, and leave a matt finish that you can then spend several hundred hours polishing...
A good media blaster can take off the paint one coat at a time.  I've seen fiberglass cleaned so that the gel coat was perfect.  But you have to find the right guy.
thejumpsuitman
Quote from: Bestekustoms on November 13, 2009, 08:28:32 PM
Good Luck
JOHN 8)
You sound like me... "Safety Third"... Right behind results and fun!  Woohoo!
Albemarle, NC
