8v92T hard to start?
Started by johns4104s, July 27, 2009, 05:31:23 PM
johns4104s
After about 500 miles today we pulled for a few minutes, the off ramp was steep so was the ramp into the truck stop. after about 20 minutes I tried to re start the motor, it took three tries the last one was about 15 turns before it started.  I normally run the motor a while at idle before I shut down could this be the reason?
PS the
gomer
John;  I don't know all the perticulars but was it spinning fast [normal] or was it just slow?  If it was slower than normal, you might have a simple connection problem. check  all the terminals and ground straps.
Gomer
as you slid down the banister of life,may the splnters point the other way
TRUST IN GOD ALWAYS. riverjordanmusic@aim.com
Gomer
johns4104s
Gomer,
It spins fast, it just does not want to start right away. Now from cold she fires on the first turn?
John, It just doesn't want to go to the desert! ;D
I'd check your ground, you might have a loose or corroded connection.
Be Safe,
niles500
*** It spins fast, it just does not want to start right away ***
You have a fuel delivery problem - FWIW
(\__/)
(")_(")
- Niles
