rv heater system question. Is this thing any good?
Started by zubzub, July 19, 2009, 05:14:01 AM
zubzub
Have this heater built into the cabin of the bus.  Has a vent out through the wall, I know nothing about RV furnaces, can anyone tell me about it?
boogiethecat
Don't know anything about your particular heater BUT as long as it works, makes enough heat for you, AND the burner box is not rusted and is hole-free & sealed, use it!!
It looks good in the photo...
This kind of construction is very common, but when the burner chamber gets rusty and a hole shows up in it, you can get killed by the CO that escapes thru the hole.  Unfortunately probably the most  common cause of heater-related death, holes in the burner box or flue.
The answer is to periodically inspect the heater, and absolutely install at least at least one (perhaps more if you're like me and don't trust your life to one doodah) CO detector.  At least one should be in the bedroom at the same height and as near as possible to where your head is when you sleep.
Then I think you're fine with this heater.  Mine is very similar and I never worry about it.
1962 Crown
San Diego, Ca
Len Silva
Looks to be in decent shape.  Terralab engineers is not the manufacturer, they are a testing lab that certifies equipment.
Hartley
Suburban Heater.
I have one similar and they work just fine.
pvcces
Generally, you can figure that they are about 75% efficient. Since the ratings(BTUs) are the fuel input, you should assume that you will only get 3/4 of the rating in BTUs into your bus.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
