allison question / help
Started by crown, June 10, 2009, 04:04:14 PM
crown
hi when i had the monaco towed the towing co. pulled
the drivers side axel the trans is a allison md-3060-3560
inside the coach i just found a tag that said pull axel
shafts  both sides ? do you think the trans is toast ?
help thanks john
john
57 crown
costa rica
Probably not-but I would check the differential-since pulling one side only will still allow at least the spider gears to rotate-maybe the transmission a bit.  The only way to check is to reassemble everything and give it a try.  Good Luck, TomC
crown
 thanks tom need to fix the moter first john
john
57 crown
costa rica
RickB
A new busnut/friend is a transmission specialist and when he asked me about towing these beasts i said that the onlt time I ever had mine towed they hooked on in front and took both axles out and he said" I wonder why they did that they only needed to pull one side". I will ask him why that is later today and get back to you.
Rick
By the way....Motor rebuilt??? whats up with that???  Sounds expensive
crown
  hi rick thanks let me known what your friend says
yes need to rebuid the moter but i live in costa rica
laber is chepper  out of frame laber is under $ 600
john
john
57 crown
costa rica
poppi
   TomC is correct..........I used to rebuild Cat powershift to 16 speed automatics and an occasional allison.
   It is not uncommon to pull just one axle for towing the big rigs. On my bus they disconnected the drive
shaft because I have chrome wheel covers and it was easier to disconnect than pull the covers off.
HTH
  Skip
Snow disappeared......Now where did I put that bus?
RickB
I'm moving there today!!! LOL
crown
 hey rick you can come down and help out i live in a big
castle high up in the mountains  john
john
57 crown
costa rica
Sojourner
All of what Tom C said and more...the own way for differential's spider gears set to get lubed is one of two things.
1)   If oil level is already right at or barely flow out of plug's hole...that is good meaning the side gears are getting lubed to the spiders.
2)   If the oil level is very low and the drive shaft can rotate freely and barely rotate while driven for the ring gear to pick-up oil ....that is good....however it may never rotate.
Suggestion....Before you drive far away from home, remove differential's oil level plug and see if it has magnetic plug. If so...good and clean off the "factory" metal compound with air blow gun and reinstall it or otherwise get a magnetic plug. Now with oil level at bottom of plug's opening, drive for at least 15 miles (25 mi is better to get it very warmed) at 65 mph to stir-up anything that is metal compound within the differential. Again remove the magnetic plug to see if any more compounds are present on the magnet. If it is mostly clear....that is good news.
BTW...the tow-er is risking his/or business reputation for just for having one axle instead of the two removed or drive shaft disconnected.
Which model Monaco coach do you have?
Glad you have it home.
Sojourn for Christ, Gerald
BTW...Monaco is now sold to Navistar as of June 4, 2009
crown
 thanks sojourn will check that out  the monaco is a 95 dynasty 40 ft
cummins 8.3 turbo with intercooler john
john
57 crown
costa rica
