What is the GPH fuel flow on an 8v71?
Started by Barn Owl, January 10, 2009, 09:58:56 PM
Barn Owl
I have been given a Davco 233 diesel pro filter. It is rated for 60 gph. Is the 8v71 total flow higher than that?  Can I use that filter or do I need the 382? I have found gph use on some marine boards but I need total flow numbers that includes pass through....right?
oldmansax
If you get 7MPG @ 60 mph you will burn about 8.5 gals fuel in 1 hour. 5 MPG will burn 12 gal/hr. 3 MPG (what I used to get with my old hot rodded 8V92) will burn 20.
TOM
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
RTS/Daytona
The "spill rate" (the amount of fuel returned to the tank)  on a 2 cycle detroit is huge
(it's used to cool the injectors)
a 6V92TA pumps 62.3 GPH at full load
rule of thumb (you burn only about 20% of what is pumped at full load)
Hope that helps
Also 88.5 GPH with the high volume pump      good luck
Barn Owl
Crap, I guess I need to look for a 382 which has a 150 gph capacity.
Davco filter link
Lin
Great information.  I would not have thought so much fuel was flowing.
steve5B
    As Oldmansax mentioned the amount of fuel per Hr. x fuel cost ....... it's rather expensive per HR. to operate.
    I never thought about it in that way.
    Steve 5B......
WWW.WINNERSCHOICECORPORATION.COM
"It's all in the name the name says it all"
oldmansax
Good info. I wasn't thinking about the returns....
Steve, when I was running that old 8v92, I was paying $0.19 to $0.25 a gallon for fuel.
If I had just put up a million gallon tank & stored fuel............  ;D ;D ;D
TOM
1972 MCI MC7
Barn Owl
QuoteAlso 88.5 GPH with the high volume pump
How does one identify a high volume pump and what is the gph for the standard pump?
Slow Rider
The MCI has landed..... We are home.
Dale City Va.  Just a southern suburb of DC
Yes I am a BUSNUT
1976 MCI MC8
